I have a problem which is probably linked to the internet problems.
I have an ubuntu 14.04 LTS as a partition on MBP, and I have very recently got the Wi-Fi driver working. However, it is very slow. Sometimes, it even does not detect the server. This behavior is probably linked to the main problem. Whenever I try to install any package using apt-get install I can think of, I get this type of error (for example):
$ sudo apt-get install squid3
Reading package lists... Done
Building dependency tree
E: Unable to locate package squid3
And when I try issuing squid3 into the Terminal, it shows:
The program 'squid3' is currently not installed. You can install it by typing:
The same error applies to all the packages I can think of. Is this because the access to ubuntu being blocked? Is it a different issue?
