29
I am trying to figure out how to write a script which would start program(s) in GNU Screen sessions(s) at system boot. I am trying this:
#!/bin/bash
screen -S test -d -m -X $HOME/folder/folder/.program \
screen -S test2 -d -m -X $HOME/folder/folder/.program2 \
but the command cant be executed because session is already detached? The only thing that i need is run command in screen session and detach this session immediately.
Thanks for answers, but now i faced another problem. Script stops working after i put some variables for my "program and program2". Something like this:
#!/bin/bash
screen -S test -d -m $HOME/folder/folder/.program -f config.cfg
for some reason "-f config.cfg" got ignored. I am also tried to quote command and doesnt help too.
TbMa
  • 535
Did you really mean to put the \ at the end of the line? If not then try removing those - they escape the following character.
also, dropping the -X helps the setup work for me, for instance:
screen -S test -d -m -X touch /tmp/test
fails with No screen session found, however:
screen -S test -d -m touch /tmp/test
works fine. As such I suspect the following will work for you:
#!/bin/bash
screen -S test2 -d -m $HOME/folder/folder/.program2
Remember, that if you run this at boot time, $HOME is not the same as after you log in as a specific user. If you need to run it as a certain user you'll need to use the likes of su to run it as that user, and specifying the full path will remove any ambiguity:
#!/bin/bash
screen -S test -d -m su - username /home/username/folder/folder/.program
screen -S test2 -d -m su - username /home/username/folder/folder/.program2
Or, you would call the entire script above as su - username /path/to/your/script.
Cry Havok
  • 1,342
Like Cry Havok mentioned, you can place the program right on the command-line.
If you really must use the -X option, then a) you need to specify the 'screen' command and b) the session needs to exist beforehand.
screen -dmS test
screen -S test -X screen $HOME/folder/folder/.program
screen -dmS test2
screen -S test2 -X screen $HOME/folder/folder/.program2
Arcege
  • 5,618
