How to remove linux-image-extra-3.13.0-49-generic from my system?
I can't install any package because of this error:
$ sudo apt-get autoremove Reading package lists... Done Building dependency tree Reading state information... Done The following packages will be REMOVED: linux-image-extra-3.13.0-49-generic 0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded. 1 not fully installed or removed. After this operation, 152 MB disk space will be freed. Do you want to continue? [Y/n] y (Reading database ... 225623 files and directories currently installed.) Removing linux-image-extra-3.13.0-49-generic (3.13.0-49.83) ... depmod: FATAL: could not load /boot/System.map-3.13.0-49-generic: No such file or directory run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 3.13.0-49-generic /boot/vmlinuz-3.13.0-49-generic run-parts: executing /etc/kernel/postinst.d/dkms 3.13.0-49-generic /boot/vmlinuz-3.13.0-49-generic run-parts: executing /etc/kernel/postinst.d/initramfs-tools 3.13.0-49-generic /boot/vmlinuz-3.13.0-49-generic update-initramfs: Generating /boot/initrd.img-3.13.0-49-generic grep: /boot/config-3.13.0-49-generic: No such file or directory depmod: WARNING: could not open /tmp/mkinitramfs_UCk0cv/lib/modules/3.13.0-49-generic/modules.order: No such file or directory depmod: WARNING: could not open /tmp/mkinitramfs_UCk0cv/lib/modules/3.13.0-49-generic/modules.builtin: No such file or directory run-parts: executing /etc/kernel/postinst.d/pm-utils 3.13.0-49-generic /boot/vmlinuz-3.13.0-49-generic run-parts: executing /etc/kernel/postinst.d/update-notifier 3.13.0-49-generic /boot/vmlinuz-3.13.0-49-generic run-parts: executing /etc/kernel/postinst.d/zz-runlilo 3.13.0-49-generic /boot/vmlinuz-3.13.0-49-generic Added Linux * Fatal: open /boot/vmlinuz-3.13.0-49-generic.efi.signed: No such file or directory run-parts: /etc/kernel/postinst.d/zz-runlilo exited with return code 1 dpkg: error processing package linux-image-extra-3.13.0-49-generic (--remove): subprocess installed post-removal script returned error exit status 1 Errors were encountered while processing: linux-image-extra-3.13.0-49-generic E: Sub-process /usr/bin/dpkg returned an error code (1)
It's not the same as http://askubuntu.com/questions/89710/how-do-i-free-up-more-space-in-boot question as apt-get purge xxx doesn't work(the same error).
