I have laptop with a 256 gb SSD with windows already installed and i want to install ubuntu on the same drive.BUT with the "/home" partition on a second 1tb HDD(600gb for windows and 400 gb for ubuntu). is it possible? will it cause problems down the line?
Asked
Active
Viewed 61 times
It is a very common installation type. Just choose manual disk partitioning, when install. Create / partition on your SSD and /home on you HDD. Do not forget to set mount points correctly.
Pilot6
- 92,041
Yes, It is possibile. When you install ubuntu choose 'Manual partitioning': - Create a new partition in your SSD and select as mountpoint '/' - Create a new partition in your HD and select as mountpoint '/home'
If you want further information about partioning and mountpoints: help - Partitioning issue or Partitioning/Home.
Nicola Corti
- 96
