I'm running Ubuntu 11.04 on a laptop, and quite often (but not always), if I open the lid to wake the computer from Suspend, the wireless connection finds nothing.
I've tried using ifup and ifdown, but to no avail. The only solution I've found is to reboot the whole system.
Any solution - a setting somewhere, a text file to edit or a script to run?
Thanks.
First find out what your wireless kernel driver you use:
Run
sudo lshw -class network
Then look for "driver=xxxxx" e.g.
Now create a text-file called "reset_wireless.sh" with the following:
#!/bin/sh
service network-manager stop
modprobe -r brcm80211
modprobe brcm80211
service network-manager start
obviously change "brcm80211" with your driver.
Give it execute rights i.e.
chmod +x reset_wireless.sh
Now right-click and create a launcher on your desktop with the command:
gksudo reset_wireless.sh
Now when you awaken you can reset your wireless by double-clicking on the new launcher.
Automating
You can try the following to automate the above script on resume:
Move the file to a known location e.g.
sudo mv ~/resume_wireless.sh /var/local
Now create a new script:
#!/bin/sh
case "$1" in
        thaw|resume)
    /var/local/resume_wireless.sh
        esac
exit $?
save this script in the folder /etc/pm/sleep.d called 99wireless-resume and give it execute rights.
technique borrowed from here and here
fossfreedom
  • 174,526
Could pm-powersave be the cause of your problem? My answer to How to connect wirelessly in a cafe with 11.04 might apply
waltinator
  • 37,856
