On Chemistry Stack Exchange I asked a question regarding Open Babel & Python being used together.
The problem is that the answer I was provided (by Geoff Hutchinson) requires Python to be able to import the module Pybel.
I have installed Open Babel on this PC via two ways, APT and source. I then deleted my APT installation after I realized pybel wasn't available for Python use and I decided to install from source with Python bindings.
To do so I followed this guide with the final command being customized to (running from ~/build)
cmake ../openbabel-2.3.2 -DBUILD_GUI=ON -DPYTHON_BINDINGS=ON
which gave the output:
-- Using included inchi library.
-- Found wxWidgets: TRUE
-- Cairo found. PNG output will be supported.
-- Attempting to build the GUI
--    wxWidgets found => GUI will be built
CMake Warning (dev) at test/CMakeLists.txt:171 (include):
  Syntax Warning in cmake code at
/home/fusion809/Downloads/openbabel-2.3.2/cmake/modules/UsePythonTest.cmake:54:14
Argument not separated from preceding token by whitespace. This warning is for project developers. Use -Wno-dev to suppress it.
CMake Warning (dev) at test/CMakeLists.txt:171 (include): Syntax Warning in cmake code at
/home/fusion809/Downloads/openbabel-2.3.2/cmake/modules/UsePythonTest.cmake:54:31
/home/fusion809/Downloads/openbabel-2.3.2/cmake/modules/UsePythonTest.cmake:57:25
/home/fusion809/Downloads/openbabel-2.3.2/cmake/modules/UsePythonTest.cmake:57:39
-- Python bindings will be compiled -- Could NOT find Ruby (missing: RUBY_INCLUDE_DIR RUBY_LIBRARY RUBY_CONFIG_INCLUDE_DIR) (found version "2.1.0") -- Ruby library files NOT found. Ruby bindings will NOT be compiled. -- Configuring done -- Generating done -- Build files have been written to: /home/fusion809/build
I should mention, however, that the first time I compiled Open Babel I forgot to add the -DBUILD_GUI & -DPYTHON_BINDINGS commands to the cmake line, so I had to run this new cmake command after I had initially compiled the software. Does this make any difference? Should I remove Open Babel and re-compile? If so do I have to delete some files in my /usr/ directory to (if so please mention them as I don't know which ones)? If relevant I am on 32 bit 15.04.
EDIT
I deleted my build directory's contents & started again and after the cmake command I ran:
make
sudo make install
export PYTHONPATH=/usr/local/lib:$PYTHONPATH
At the end of the output I received were these two lines:
-- Up-to-date: /usr/local/lib/openbabel.py
-- Up-to-date: /usr/local/lib/pybel.py
In a Python terminal I ran import openbabel and import pybel and it gave the output: ImportError: No module named ... where ... is openbabel or pybel, depending on which of the commands were executed, so I suspect it's a problem on my Python installation's end.
Josh Pinto
  • 8,089
Without python-openbabel:
% python
Python 2.7.9 (default, Apr  2 2015, 15:33:21)
[GCC 4.9.2] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> import openbabel
Traceback (most recent call last):
  File "<stdin>", line 1, in <module>
ImportError: No module named openbabel
% python
>>> import pybel
ImportError: No module named pybel
Install python-openbabel:
sudo apt-get install python-openbabel
Check:
% python
>>> import openbabel
% python
>>> import pybel
A.B.
  • 92,125
I had the same problem and figured out that I was using a python distribution (Anaconda) other than the original (the one provided by Ubuntu). Below is a potential workaround (if this is the case).
After installing python-openbabel using apt-get, check it with the system-provided python (in my case /usr/bin/python). You should be able to import openbabel:
% /usr/bin/python
Python 2.7.6 (default, Jun 22 2015, 17:58:13)
[GCC 4.8.2] on linux2
>>> import openbabel
I tried to use easy_install provided by Anaconda to install openbabel & pybel but it was not successful. Then I copied the *openbabel* and *pybel* files in /usr/lib/python2.7/dist-packages/ to a folder that PYTHONPATH sees and it worked fine. I would appreciate if anyone has a nicer (cleaner) way to make Anaconda use of the package installed for system-provided python.
(I wanted to comment to the answer but due to the lack of reputation I couldnt)
emre
  • 301
