I want to uninstall XAMPP on Ubuntu on VM. Please advise command to archive this.
I have downloaded package using wget command and run sudo ./xampp-linux-1.8.3-2-installer.run. How to delete folder using terminal located at /opt/lampp?
As stated in this post:
To Uninstall Xampp, use
sudo -i cd /opt/lampp ./uninstall
But I think you may simplify by just typing:
sudo /opt/lampp/uninstall
Open a terminal and remove the folder with:
sudo rm -r /opt/lampp
That's all.
But since I do not know where you have downloaded the installation file, I can not prove what was also installed.
Simply,
Open Terminal
Run command sudo /opt/lampp/uninstall
A popup of xampp will jump asking whether you are sure about this uninstallation.
Click yes
TADAA.. It's done.
Open terminal and type the following commands to uninstall XAMPP:
cd /opt/lampp
sudo ./uninstall
Removing Xampp completely from Ubuntu 20.04 is way too easy than before. Open the terminal by typing Ctrl+Alt+T and then type the following command:
And boom! You're good to go. If you got any other Linux distro then just go through these simple blog posts about Removing Xampp and you'll find all commands there.
