I will be using my Ubuntu for neuroimaging use. This is my first time using -- I've been using Macs for the last few years so am not familiar with using Ubuntu on a regular PC. A few questions: Are root, swap, and home partitions necessary? I plan to install Ubuntu on an HDD (1TB), with my Windows on a separate SSD (256GB).
My specs are as follows:
Processor: i7, 3.6GHz, RAM: 32GB
I am wondering what I should do to 'max' it out, as I plan to run pretty intensive imaging analyses on Ubuntu. I will only be using Windows for Office and probably SPSS and Matlab. If necessary, how big should each partition likely be given this context?
In addition, I would like to dual boot. The advice given has been quite scattered and confusing thus far, so I'd like to confirm this here. I guess the more ideal choice would be to boot Windows from Ubuntu and not the other way around. If so, what should I select in the 'device for boot loader installation' option when installing? Should it be the sda (Windows disk) or the sdb (Ubuntu)?
Thanks very much.
-M.
As to part 1 of this post: Swap with those specs is purely a preference but even /home is not required BUT given your use case HIGHLY HIGHLY recommended as /home is where all those imaging files will go NOT root (/).
as for part 2 of this post: you will need to better define "maxing it out" but also of note LibreOffice and kingsoft Office are BOTH in ubuntu repos and do 98% of Office suite / mathlab is as well,
I personally would have bootloaders on both drives with the primary OS having control of the loader on that disk(s) using winboot for the (mostly) windows drve and grub on the linux drive.
