I have installed cmatrix using the command:
sudo apt-get install cmatrix
And when running the command:
cmatrix -l
In console (the ttys) I get a very cool looking font with matrix like symbols. But when I run it with that option in gnome-terminal I just get this output:
Couldn't get a file descriptor referring to the console
Although it works without the -l in gnome-terminal, it does not give me the special font, so is there any way of running it in gnome-terminal and also getting the same font that running it with the -l option in the console would result in?
OS Information:
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 15.10
Release:    15.10
Codename:   wily
Flavour: GNOME
GNOME Version: 3.18
Package Information:
cmatrix:
  Installed: 1.2a-5build1
  Candidate: 1.2a-5build1
  Version table:
 *** 1.2a-5build1 0
        500 http://archive.ubuntu.com/ubuntu/ wily/universe amd64 Packages
        100 /var/lib/dpkg/status
It's -l mode, quoting from the manual page:
  -l    Linux mode (sets "matrix.fnt" font in console)
It requires that you run it on one of the Linux consoles (the ones Ctrl+Alt+F1 ... Ctrl+Alt+F6 switch to).
In a graphical terminal emulator it has no way of changing the font of the terminal. You can still use it there without the -l flag.
egmont
  • 8,990
  • 34
  • 47
