When my AquarisE4.5 Ubuntu phone is connected by USB and I fire up Banshee (with MTP support), it throws the phone mount, and I can't remount until Banshee is closed. Syslog said:
May 13 05:30:10 CANTANDO kernel: [ 500.700012] usb 2-1: reset high-speed USB device number 3 using xhci_hcd
May 13 05:30:10 CANTANDO kernel: [ 500.715964] xhci_hcd 0000:03:00.0: xHCI xhci_drop_endpoint called with disabled ep ffff8800a03aa700
May 13 05:30:10 CANTANDO kernel: [ 500.718658] usb 2-1: usbfs: process 4181 (banshee) did not claim interface 0 before use [...]
When I removed the MTP support on Banshee, the problem disappeared.
Is there a way for these two things to coexist?
lash
  • 161
This is a workaround if you don't want Banshee to mount your phone ever. Open up preferences in Banshee without your phone plugged in and disable the "MTP Media Player Support" under 'extensions/Device Support'. Then restart banshee and plugin your phone.
Now Banshee does not mount your phone. Works for me.
joanna
