Is it possible to downgrade from ubuntu 15 to ubuntu 14?
We would like to stay on 14 until we have decided on a distro to replace ubuntu that does not use systemd.
How is that done?
It's a risky thing to try a rollback, there's no easy way to downgrade.
Best option: After backing up your stuff, re-install the OS.
As user1362567 said on another question
First generate a list of what you have installed on your system. You can do this by typing the following in the terminal.
sudo dpkg --get-selections | grep '[[:space:]]install$' | \awk '{print $1}' > package_list
copy your /home and /etc folder to a backup media.
Re-install the desired ubuntu version [Mentioned in the original thread : 10.04], and then run this command to install what you had before.
cat package_list | xargs sudo apt-get install
Note that you might have to do some cleaning of the /etc and /home folder for incompatible settings. " I have to thank user1362567 for explaining it well. Link to the original post : How to roll back Ubuntu to a previous version?
