If it can be done using mimicking the function keys play and pause, or I want it in clementine only so using the clementine command line.
Asked
Active
Viewed 166 times
Clementine supports standard Global Hotkeys, such as Multimedia Keys, as well as custom setups. Your best bet would be to modify this post on how to mute audio when your headset becomes disconnected to send the Multimedia Pause key.
Basically, a file (/proc/asound/card0/codec#0) will change depending upon whether or not headphones are connected. You would monitor this file (inotify) and depending on the file's content, send the Multimedia Pause.
earthmeLon
- 11,658
