I turned an old PC into a server by installing Ubuntu Desktop 10.10 some time ago, and I really love it, but it's outdated and I think it's time for an upgrade. It's specs are the following:
  • Core 2 Duo E6850
  • 2 GB Ram 800 MHz
  • 40 GB IDE HDD (the only spare I had)
My problem is that only the GUI from 10.10 which I believe is Gnome 2.32, offers VNC which works without problems, and is lightweight enough not to lag my server.
How can I upgrade to Ubuntu 14.04 and also keep the old GUI?
Should I install Ubuntu Server and then the GUI? If so, how?
I am basically looking to install Gnome 2.32 on a newer Ubuntu version.
Braiam
  • 69,112
You have many disparate issues here I want to address.
Ubuntu Server is (as far as is important for your use) just Ubuntu without the graphical desktop packages installed. That is to say, if you want a clean install of Ubuntu Server with a graphical desktop, you might as well just install the Ubuntu spin for that desktop (eg Ubuntu Mate, Kubuntu, etc) and then install things like LAMP (or whatever server tasks you need) with tasksel or Apt.
The Ubuntu desktop of the 2010 era is long gone. It moved onto Unity. If you upgrade the ubuntu-desktop metapackage will pull you onto Unity. You could just uninstall those packages before upgrading (and run an apt-get autoremove) and then install whatever -desktop metapackage (probably mate-desktop) when you're done upgrading the core system.
10.10 has been dead for years. As has 11.04 and 11.10. You'll need to upgrade through all of those to get to 12.04 and from there you should be able to LTS-hop to 14.04. That's another reason for getting rid of any non-essential packages (less to upgrade).
Honestly, I'd be weighing up whether it's not best to back-up and do a fresh install of Ubuntu Mate (or whatever desktop spin takes your fancy - there are many now). It'll be much faster for you and will likely leave you with a better result.
Oli
  • 299,380
Well GNOME 2 is completely obsolete, and has been since 12.04, but you can get GNOME 3. Ubuntu MATE is a sub-distro of Ubuntu which aims to bring back the old GNOME interface. It's not going to be exactly the same, but it is very similar.
Ubuntu MATE 14.04 ISO
TheWanderer
  • 19,525
  • 52
  • 65
