Is there an easy way to install Lubuntu on an old T41 with a Celeron M?
What I tried:
- Downloaded the 32 Bit version of Lubuntu
- install Ubuntu 15.04 on my USB drive with
unetbootin additionally after finding this bug report, I run the following commands:
cd /usr/lib/syslinux/modules/bios/ cp libcom32.c32 /media/path/to/usb/drive/ cp libutil.c32 /media/path/to/usb/drive/ cp menu.c32 /media/path/to/usb/drive/
Now only this message is left:
WARNING: PAE disabled. use parameter 'forcepae' to enable at your own risk!
This Kernel requires the following features not present on the CPU:
pae
It seems I have to install fake-PAE on my USB drive as well somehow, but I only found solutions how to install that with apt-get in a running system
UPDATE:
I pressed tab in the Grub menu of the USB installer and added forcepae at the end of the showing commandline:
/ubnkern initrd=/ubninit forcepae
Then it started booting, but then after a while I get a BusyBox shell.
So this doesn't seem to be the whole solution.
How do I install Lubuntu on a T41?
I guess that would be a not desirable workaround:
install 12.04 and upgrade twice to the latest version.
