I updated to Ubuntu Vivid the other day, and now I am having problems. I cannot get dnscrypt-proxy to start (amongst other programs). I am guessing it has to do with the systemd switch. This is what happens when I try to start dnscrypt-proxy:
$ sudo service dnscrypt-proxy start
[sudo] password for anon:
Failed to start dnscrypt-proxy.service: Unit
dnscrypt-proxy.service failed to load: No such file or directory.
There's nothing wrong with my init script or installation, I tried reinstalling and then rebooting... no go.
I'm sure there is a simple answer to this that I am overlooking. If someone could help me understand the key differences with systemd and what I need to do to get services to start, I would really really appreciate it.
Chev_603
  • 1,728
First of all let me thank all of those that commented above.
UPDATED - This is what worked on Ubuntu Mate 15.10.
Download Simon Clausen's script linked below.
https://github.com/simonclausen/dnscrypt-autoinstall.
Ubuntu 15:10 breaks Simon Clausen's script so that it only works until you reboot. This is because Ubuntu 15.10 has a symlink from /run/resolvconf/resolv.conf to /etc/resolv.conf. Simon tries to lock down the /etc/resolv.conf using chattr +i /etc/resolv.conf which fails. To fix this do the following before running his script.
sudo rm /etc/resolv.conf
sudo cp /run/resolvconfig/resolv.conf /etc/resolv.conf
Note: The new versions of dnscrypt downloaded by Simons script take systemd into account without modification.
Once the script was run and tested, I did the following.
I used the above systemd file, but needed the resolver added to the last line after all.
[Unit]
Description=DNSCrypt client proxy
Requires=dnscrypt-proxy.socket
[Install]
Also=dnscrypt-proxy.socket
WantedBy=multi-user.target
[Service]
Type=simple
NonBlocking=true
ExecStart=/usr/local/sbin/dnscrypt-proxy -R dnscrypt.eu-nl
create a text file from the text above and name it
then put your new dnscrypt-proxy.service file into
/etc/systemd/system/
We do not overwrite /lib/systemd default service definitions or we'll have troubles when the package is updated. Systemd checks /etc/systemd/system first before /lib so you're safe putting your customized service definitions in /etc/systemd.
When done, the full path is
/etc/systemd/system/dnscrypt-proxy.service
same thing - use /etc/
Next create the dnscrypt-proxy.socket file from the sample below.
[Unit]
Description=dnscrypt-proxy listening socket
After=network.target
[Socket]
ListenStream=127.0.0.2:53
ListenDatagram=127.0.0.2:53
[Install]
WantedBy=sockets.target
it also goes in
The full path is
/etc/systemd/system/dnscrypt-proxy.socket
Activate the scripts (which creates symlinks in the correct folders)
sudo systemctl enable /etc/systemd/system/dnscrypt-proxy.socket
sudo systemctl enable /etc/systemd/system/dnscrypt-proxy.service
stop the service so systemd can start it correctly.
sudo /etc/init.d/dnscrypt-proxy stop
you should take all the settings you have in /init.d/dnscrypt and move them to /etc/systemd/system/dnscrypt-proxy.service -- else systemd takes the scripts found in etc/init.d and makes a temp service definition you can find in /run/systemd/generator/XYZ.service. If you have a service in /etc/ with the same name as a script in init.d, the script gets ignored in favor of the service def'n
you shouldn't see any errors when starting the service with.
sudo systemctl start dnscrypt-proxy.service
This method survives a reboot for me on Ubuntu 15.10.
I am NOT an advanced user of Linux in any way. I just started. Thanks go to Chev_603 and all those he credited, not me. I hope you find this help full. Any comments about improving the scripts would be appreciated. It would be nice to have a secondary DNS server. Anyone know how?
Jonathan
  • 133
Okay, I finally figured out to get this to work. I purged my current installation and removed the ppa, because as solsTiCe mentioned, the package is broken. Than I grabbed this auto-install script from github. I compiled the package, however the configure script has a bug where it does not properly detect if systemd is present (even if you use the --with-systemd flag). To fix that, I opened the configure script and set the variable HAVE_SYSTEMD to TRUE manually. Than I reran configure, than make, and finally sudo make install.
Next, I created a directory, /etc/systemd/system/dnscrypt-proxy.service and placed these two scripts in that directory:
Update:This solution worked until I rebooted, but than the service did not start. I ended up using this script which now works flawlessly. Simclausen is my hero for writing this. Thanks to zenester for telling me the correct syntax:
/etc/systemd/system/dnscrypt-proxy.service/dnscrypt-proxy.service :
[Unit]
[Install]
[Service]
Type=simple
NonBlocking=true
ExecStart=/usr/local/sbin/dnscrypt-proxy \
-R dnscrypt.eu-nl
Apparently this is not necessary:
And also /etc/systemd/dnscrypt-proxy.service/dnscrypt-proxy.socket :
[Unit]
[Socket]
[Install]
Finally, I ran /usr/local/sbin/dnscrypt-proxy start -R dnscrypt.eu-nl --local-address 127.0.0.2:53
The program started succesfully. To confirm that, I ran this command:
dig @127.0.0.2 debug.opendns.com txt
And everything looks good!
; <<>> DiG 9.9.5-9-Ubuntu <<>> @127.0.0.2 debug.opendns.com txt
; (1 server found)
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 45692
;; flags: qr rd ra; QUERY: 1, ANSWER: 6, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 4096
;; QUESTION SECTION:
;debug.opendns.com.     IN  TXT
;; ANSWER SECTION:
debug.opendns.com.  0   IN  TXT "server 3.otp"
debug.opendns.com.  0   IN  TXT "flags 20 0 70 5950800000000000000"
debug.opendns.com.  0   IN  TXT "originid 0"
debug.opendns.com.  0   IN  TXT "actype 0"
debug.opendns.com.  0   IN  TXT "source xxxxxxxxxx:35164"
debug.opendns.com.  0   IN  TXT "dnscrypt enabled (xxxxxxxxxxxxxx)"
;; Query time: 154 msec
;; SERVER: 127.0.0.2#53(127.0.0.2)
;; WHEN: Fri May 22 17:24:32 EDT 2015
;; MSG SIZE  rcvd: 248
Or to correctly register it as a service:
sudo systemctl enable dnscrypt-proxy.service
And than call it with sudo service dnscrypt-proxy start I hope this helps someone.
Chev_603
  • 1,728
How did you install dnscrypt-proxy ? There is no such package in vivid.
Your package is broken as it should have included a systemd .service file to run it.
Try this file and name it /etc/systemd/system/multi-user.target.wants/dnscrypt-proxy.service
[Unit]
[Install]
[Service]
Type=simple
NonBlocking=true
ExecStart=/usr/sbin/dnscrypt-proxy -R dnscrypt.eu-nl
And this one /etc/systemd/system/sockets.target.wants/dnscrypt-proxy.socket
[Unit]
[Socket]
ListenStream=127.0.0.1:53
ListenDatagram=127.0.0.1:53
[Install]
solsTiCe
  • 9,515
I am the one owning the PPA Anton+ for dnscrypt-proxy. I learned during my vacations of the problem affecting Ubuntu systems using only systemd vs. upstart (or both) for previous releases.
I just managed to build dnscrypt-proxy for Vivid 15.04 today. It is using systemd.
However I do not have Vivid 15.04 installed in my systems. I still use Trusty 14.04 for now.
Can you test this new release on your system ? It is still version 1.5.0. If the tests are successful I will provide the newer version 1.6.0.
https://launchpad.net/~anton+/+archive/ubuntu/dnscrypt
New test build is : dnscrypt-proxy 1.5.0-1pmo1.8~vivid
It should provide for the 2 DNS from dnscrypt.eu
Contact me through Launchpad.
Thanks.
Antonio
  • 1,656
