Playing around with learning how to run an Ubuntu server (specifically, trying to set up Prosody as per a video on ArsTechnica, and a Linode guide), using Virtualbox. I've got it up and running, everything seems to be OK, until I try to update. Then I get several "failed to fetch" warnings because of hash sums? (Would post terminal output but I can't post links with <10 reputation!)
The "failed to fetch" bits seem bad, is this bad?
Also, following along with the linode guide, adding the prosody key works fine, but the same things happen upon trying to update again. Apt-get upgrade seemingly works fine and doesn't throw up any warnings or errors.
Next, upon trying to install Prosody itself, I get yet another problem:
root@Tserver:~# apt-get install prosody liblua5.1-sec0
Reading package lists... Done
Building dependency tree
The following information may help resolve the situation:
 prosody : Depends: lua-expat but it is not installable or
                    liblua5.1-expat0 but it is not installable
           Depends: lua-filesystem but it is not installable or
                    liblua5.1-filesystem0 but it is not installable
I'm seemingly unable to install any of the dependencies on their own, either.
I'm self-admittedly a total noob when it comes to these things - am I missing something here?
Ron
  • 20,938
Fixed by upgrading the server to 14.04LTS. Don't know why 12.04LTS was having that issue, but everything is up and running now.
