So I had updated ubuntu 12.04 to 14.04 and while computer was rebooting I turned it down and automaticly this showed:
error : ELF header smaller than expected .
Grub rescue>
Maythux
  • 87,123
Ivan
Boot from a LiveCD of your distribution, select the Advanced mode, then choose Recovery mode (you have to enter the shell). After you do this, and assuming that your bootloader is installed on /dev/sda, run this shell supercommand:
update-grub && grub-install /dev/sda && telinit 6
Your computer will be restarted. Remove the LiveCD from the drive, so your computer can boot its operating system in "normal" mode.
Yuri Sucupira
  • 1,024
  • 15
  • 28
