This is my current version of Ubuntu:
root@vps132318:~# lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 14.04.2 LTS
Release:    14.04
Codename:   trusty
I know this question has been asked several times and I checked them all. For all of their cases, the problem was their current version of Ubuntu. Although I use the 14.04 version, and when I type
root@ssss:~# sudo add-apt-repository ppa:kurento/kurento
kurento/kurento
Executing: gpg --ignore-time-conflict --no-options --no-default-keyring --
homedir /tmp/tmp.mvnesaHwib --no-auto-check-trustdb --trust-model always --
keyring /etc/apt/trusted.gpg --primary-keyring /etc/apt/trusted.gpg --
keyserver keyserver.ubuntu.com --recv-keys
root@ssss:~# sudo apt-get update
W: Failed to fetch
http://ppa.launchpad.net/kurento/kurento/ubuntu/dists/lucid/main/binary-amd64/Packages  404  Not Found
W: Failed to fetch http://ppa.launchpad.net/kurento/kurento/ubuntu/dists/lucid/main/binary-i386/Packages  404  Not Found
E: Some index files failed to download. They have been ignored, or old ones used instead.
root@ssss:~# sudo apt-get install kurento-media-server
Reading package lists... Done
Building dependency tree
E: Unable to locate package kurento-media-server
The two solutions I found around were:
  1. add-key one; but for their cases, the --recv-keys part was giving them a key, so they were adding the key. Mine doesn't. Missing key is not given to me.
  2. sudo update apt-get, however, no luck for me again.
  3. I have also tried to apt-upgrade, no luck eithe.
  4. Lastly, I tried clearing trusted.gpg.d directory, but no luck again.
  5. Automatically importing all missing GPG keys. But when I try sudo launchpad-getkeys, this is what I get:
    Trying to import all the missing keys
    Executing: gpg --ignore-time-conflict --no-options --no-default-keyring --homedir /tmp/tmp.emB6wtnXhs --no-auto-check-trustdb --trust-model always --keyring /etc/apt/trusted.gpg --primary-keyring /etc/apt/trusted.gpg --keyserver hkp://keyserver.ubuntu.com:80 --keyserver-options http-proxy= --recv-keys
    Executing: gpg --ignore-time-conflict --no-options --no-default-keyring --homedir /tmp/tmp.8jUZsvy2cn --no-auto-check-trustdb --trust-model always --keyring /etc/apt/trusted.gpg --primary-keyring /etc/apt/trusted.gpg --keyserver hkp://keyserver.ubuntu.com:80 --keyserver-options http-proxy= --recv-keys
    Executing: gpg --ignore-time-conflict --no-options --no-default-keyring --homedir /tmp/tmp.1pWJuVDYhk --no-auto-check-trustdb --trust-model always --keyring /etc/apt/trusted.gpg --primary-keyring /etc/apt/trusted.gpg --keyserver hkp://keyserver.ubuntu.com:80 --keyserver-options http-proxy= --recv-keys
    Executing: gpg --ignore-time-conflict --no-options --no-default-keyring --homedir /tmp/tmp.db8jIl1DVT --no-auto-check-trustdb --trust-model always --keyring /etc/apt/trusted.gpg --primary-keyring /etc/apt/trusted.gpg --keyserver hkp://keyserver.ubuntu.com:80 --keyserver-options http-proxy= --recv-keys
    Executing: gpg --ignore-time-conflict --no-options --no-default-keyring --homedir /tmp/tmp.VpS5aiBz52 --no-auto-check-trustdb --trust-model always --keyring /etc/apt/trusted.gpg --primary-keyring /etc/apt/trusted.gpg --keyserver hkp://keyserver.ubuntu.com:80 --keyserver-options http-proxy= --recv-keys
    launchpad-getkeys has finished importing all missing GPG keys. Try running sudo apt-get update - you shouldn't see any key  errors any more.
    Note that launchpad-getkeys imports missing GPG keys but does not fix broken keys.
    And then sudo apt-get update:
    Err http://ppa.launchpad.net lucid/main amd64 Packages
    404  Not Found
    Err http://ppa.launchpad.net lucid/main i386 Packages
    404  Not Found
    Ign http://ppa.launchpad.net lucid/main Translation-en_GB
    W: Failed to fetch
Am I missing out something or doing something wrong?
David Foerster
  • 36,890
  • 56
  • 97
  • 151
senty
  • 113
For whatever reason, there is a 10.04 PPA in your sources. Look closely at the erring URL:
lucid is 10.04.
It's possible you have two entries of that PPA, one for 14.04, which you added just now, and one for 10.04, probably a hangover of some upgrade. Do grep lucid /etc/apt/sources.list /etc/apt/sources.list.d/*.list, find the offending entries and delete them.
muru
  • 207,228
