As shown in the manpages tmux supports the set-clipboard option to control the system clipboard using the terminal escape codes \e]52;...\007. I would like to use this functionality in gnome-terminal, but I cannot figure out how to enable it. The manpage says the following needs to be configured for XTerm:
disallowedWindowOps: 20,21,SetXprop
But this does not seem to work for gnome-terminal. Is there a way to do this?
WouterH
  • 142
Sorry, gnome-terminal doesn't support this.
The actual emulation is handled by the vte widget. In its source code, src/caps.c contains the table where matching/parsing the incoming escape sequences begins. \e] is called OSC here, and OSC "52..." is not defined here.
egmont
  • 8,990
  • 34
  • 47
