I am using Ubuntu 12.04.5 LTS
Release: 12.04
Codename: precise
I want to install Virtualmin on my VPS, but I am getting errors while installating. Check the below errors:
INFO - Removing Debian standard Webmin package, if they exist...
INFO - Removing Debian apache packages...
INFO - Installing dependencies using command: /usr/bin/apt-get --config-file apt.conf.noninteractive -y --force-yes install bsdutils postfix postfix-pcre webmin usermin ruby libxml-simple-perl libcrypt-ssleay-perl unzip zip libfcgi-dev bind9 spamassassin spamc procmail procmail-wrapper libnet-ssleay-perl libpg-perl libdbd-pg-perl libdbd-mysql-perl quota iptables openssl python mailman subversion ruby irb rdoc ri mysql-server mysql-client mysql-common postgresql postgresql-client awstats webalizer dovecot-common dovecot-imapd dovecot-pop3d proftpd libcrypt-ssleay-perl awstats clamav-base clamav-daemon clamav clamav-freshclam clamav-docs clamav-testfiles libapache2-mod-fcgid apache2-suexec-custom scponly apache2 apache2-doc libapache2-svn libsasl2-2 libsasl2-modules sasl2-bin php-pear php5 php5-cgi libapache2-mod-php5 php5-mysql
...in progress, please wait...
.E: Unable to correct problems, you have held broken packages.
/usr/bin/apt-get --config-file apt.conf.noninteractive -y --force-yes install bsdutils postfix postfix-pcre webmin usermin ruby libxml-simple-perl libcrypt-ssleay-perl unzip zip libfcgi-dev bind9 spamassassin spamc procmail procmail-wrapper libnet-ssleay-perl libpg-perl libdbd-pg-perl libdbd-mysql-perl quota iptables openssl python mailman subversion ruby irb rdoc ri mysql-server mysql-client mysql-common postgresql postgresql-client awstats webalizer dovecot-common dovecot-imapd dovecot-pop3d proftpd libcrypt-ssleay-perl awstats clamav-base clamav-daemon clamav clamav-freshclam clamav-docs clamav-testfiles libapache2-mod-fcgid apache2-suexec-custom scponly apache2 apache2-doc libapache2-svn libsasl2-2 libsasl2-modules sasl2-bin php-pear php5 php5-cgi libapache2-mod-php5 php5-mysql failed.  Error (if any): 0
Displaying the last 15 lines of /root/virtualmin-install.log to help troubleshoot this problem:
sasl2-bin is already the newest version.
unzip is already the newest version.
php5 is already the newest version.
php5-cgi is already the newest version.
php5-cgi set to manually installed.
php-pear is already the newest version.
 libapache2-mod-fcgid : Depends: apache2.2-common but it is not going to be installed
 libapache2-svn : Depends: apache2.2-common but it is not going to be installed
FATAL - Fatal Error Occurred: Something went wrong during installation: 0
FATAL - Cannot continue installation.
FATAL - Attempting to remove virtualmin repository configuration, so the installation can be
FATAL - re-attempted after any problems have been resolved.
FATAL - Removing temporary directory and files.
FATAL - If you are unsure of what went wrong, you may wish to review the log
FATAL - in /root/virtualmin-install.log
I have also tried apt-get update and apt-get -f install.
I have removed Apache but no success.
Please help me out with this issue.
karel
  • 122,292
  • 133
  • 301
  • 332
