I have this script below, and I need run it on starup in my Ubuntu Server. Where I can put it? In rc.local? Thanks in advanced!
  #!/bin/sh
  # Variaveis
  LOIF="lo"
  LOIP="127.0.0.1/32"
  LOOPBACKIF="lo"
  LOOPBACKIP="127.0.0.1/32"
  INTIF="eth0"
  INTIP="192.3.1.2/32"
  REDEINT="192.3.1.0/24"
  EXTIF="eth1"
  EXTIP="192.168.1.8/32"
  UNIVERSO="0.0.0.0/0"
  PALTAS="1024:65535"
  IPTABLE="/sbin/iptables"
  LOGGING="-l"
  # Geral
  echo " - Desabilitando ataques de IP Spoofing."
  echo "2" > /proc/sys/net/ipv4/conf/all/rp_filter
  # Habilitando FORWARDing
  echo "1" > /proc/sys/net/ipv4/ip_forward
  # Kill Timestamps
  echo "0" > /proc/sys/net/ipv4/tcp_timestamps
  # Habilitando protecao a Cookie TCP SYN
  echo " - Habilitando protecao a Cookie TCP SYN."
  echo "1" > /proc/sys/net/ipv4/tcp_syncookies
  # Certifique que as configuracoes de diversos ICMP sanity estao presentes.
  echo " - Habilitando configuracoes de ICMP."
  # Desabilitando protecao a echo de broadcast ICMP.
  echo "1" > /proc/sys/net/ipv4/icmp_echo_ignore_broadcasts
  # Habilitando protecao a mensagem de "bad error"
  echo "1" > /proc/sys/net/ipv4/icmp_ignore_bogus_error_responses
  # Desabilitando redirecionamentos de ICMP
  echo "0" > /proc/sys/net/ipv4/conf/all/accept_redirects
  # Logar pacotes spoofed, roteados na origem ou redirecionados.
  echo " - Logar pacotes spoofed, roteados na origem ou redirecionados "
  echo "1" > /proc/sys/net/ipv4/conf/all/log_martians
  # Set out local port range
  echo "32768 61000" > /proc/sys/net/ipv4/ip_local_port_range
  # Reduce Dos'ing ability by reducing timeout
  echo "30" > /proc/sys/net/ipv4/tcp_fin_timeout
  echo "1800" > /proc/sys/net/ipv4/tcp_keepalive_time
  echo "0" > /proc/sys/net/ipv4/tcp_window_scaling
  echo "0" > /proc/sys/net/ipv4/tcp_sack
  # Carga dos Modulos
  /sbin/modprobe ip_tables
  /sbin/modprobe iptable_filter
  /sbin/modprobe ip_nat_ftp
  /sbin/modprobe iptable_nat
  /sbin/modprobe ip_conntrack
  /sbin/modprobe ip_conntrack_ftp
  #Regra para pacotes com defeito
  $IPTABLE -A FORWARD -m state --state ESTABLISHED,RELATED -j ACCEPT
  $IPTABLE -A INPUT -m state --state INVALID -j DROP
  $IPTABLE -A FORWARD -m state --state INVALID -j DROP
  $IPTABLE -t nat -A POSTROUTING -s $REDEINT -d $UNIVERSO -o $EXTIF -j MASQUERADE
In my rc.local
  #!/bin/sh -e
  # rc.local
  # This script is executed at the end of each multiuser runlevel.
  # Make sure that the script will "exit 0" on success or any other
  # value on error.
  # In order to enable or disable this script just change the execution
  # bits.
  # By default this script does nothing.
  noip2
  # Variaveis
  LOIF="lo"
  LOIP="127.0.0.1/32"
  LOOPBACKIF="lo"
  INTIF="eth0"
  EXTIF="eth1"
  PALTAS="1024:65535"
  LOGGING="-l"
  # Geral
  # Kill Timestamps
  # Carga dos Modulos
  exit 0
Vitor Mazuco
  • 1,461
Yes. Edit /etc/rc.local and put your commands there. Remember to end the script with exit 0
Ron
  • 20,938
