35
I'm on 15.04 64 bit Lubuntu and I downloaded chrome from their website, because it can be useful at times, but I want to keep firefox as my default browser and despite having put it as default browser it still doesn't run when I execute x-www-browser. I then manually put firefox as default using the update-alternatives script, but what made me wonder was why chrome put itself at a priority of 200. I don't regard chrome as high as they do themselves, so how would I be able to change the priorities?
This is what I have now and firefox did indeed become my default application, but it shouldn't have, when I clearly put it as default in the firefox interface itself.
  Selection    Path                           Priority   Status
  0            /usr/bin/google-chrome-stable   200       auto mode
  1            /usr/bin/chromium-browser       40        manual mode
* 2            /usr/bin/firefox                40        manual mode
  3            /usr/bin/google-chrome-stable   200       manual mode
Peter Raeves
  • 1,109
You can change the priority with:
sudo update-alternatives --install /usr/bin/x-www-browser x-www-browser google-chrome-stable <priority_as_integer>
Example:
before
$ sudo update-alternatives --config x-www-browser
There are 2 choices for the alternative x-www-browser (providing /usr/bin/x-www-browser).
* 0            /usr/bin/google-chrome-beta   150       auto mode
  1            /usr/bin/firefox              150       manual mode
  2            /usr/bin/google-chrome-beta   150       manual mode
after:
$ sudo update-alternatives --install /usr/bin/x-www-browser x-www-browser /usr/bin/google-chrome-beta 50
update-alternatives: using /usr/bin/firefox to provide /usr/bin/x-www-browser (x-www-browser) in auto mode
* 0            /usr/bin/firefox              150       auto mode
  2            /usr/bin/google-chrome-beta   50        manual mode
A.B.
  • 92,125
16
In short: edit /var/lib/dpkg/alternatives/x-www-browser and change priority inside
DETAILS
An easiest and the must answer is to edit the administrative update-alternative files found in the /var/lib/dpkg/alternatives
So edit the x-www-browser file
sudo gedit /var/lib/dpkg/alternatives/x-www-browser
The output will be like this:
auto
/usr/bin/firefox
40
200
/usr/bin/vivaldi-stable
200
Now easily change the priority of chrome (200) by whatever you want then save. (I changed to 50)
check the new settings
update-alternatives --query x-www-browser
Link: x-www-browser
Status: auto
Best: /usr/bin/vivaldi-stable
Value: /usr/bin/google-chrome-stable
Alternative: /usr/bin/firefox
Priority: 40
Alternative: /usr/bin/google-chrome-stable
Priority: 50
Alternative: /usr/bin/vivaldi-stable
Priority: 200
Maythux
  • 87,123
I have qutebrowser installed to ~/.local/bin which is on my $PATH. I had put the full path to the executable, meaning I had to run
sudo update-alternatives --install /usr/bin/x-www-browser x-www-browser $HOME/.local/bin/qutebrowser 200
instead of using qutebrowser only as second-to-last argument (because update-alternatives complained about the path not being absolute) then
EDIT: I'm on debian buster/sid, HTH anyways. EDIT2: Reasoning why I had to specify the full path to qutebrowser.
pylipp
