13
When I type
sudo su
It asks for my user password. And when I type just
su
It asks for the root user password. But both the commands directs me to the root terminal. Then why is there such a difference?
NAND
  • 117
sudo su means run the command su as sudo which means as root. Here the system will ask you for your password since you are a sudoer. After you enter your password, you now have root privileges. So su command won't ask for a password. It's same as if you are a root then su to any other user will not ask for password because you are a root.
When you just run the command su, you are running it as a regular user. Since su means switch to user root, you will be asked for the root password.
Maythux
  • 87,123
