I noticed after doing apt-get dist-upgrade that pulseaudio was using 100% of one of the CPUs on my server. I can stop it but it restarts after after rebooting. Why would this have been installed and what would be the safest way to get rid of it? I was going to use apt-get autoremove pulseaudio but then it said it was going to install other packages:
The following extra packages will be installed:
gnome-control-center gnome-control-center-data gnome-settings-daemon
libgnome-control-center1 libgoa-backend-1.0-1 libtelepathy-glib0
Suggested packages: libcanberra-gtk-module metacity x-window-manager
The following packages will be REMOVED:
indicator-sound libcanberra-pulse pulseaudio pulseaudio-module-x11
unity-control-center unity-control-center-signon
The following NEW packages will be installed:
gnome-control-center gnome-control-center-data gnome-settings-daemon libgnome-control-center1 libgoa-backend-1.0-1 libtelepathy-glib0
0 upgraded, 6 newly installed, 6 to remove and 1 not upgraded.
Tim
  • 33,500
brian
Don't remove it, it's part of the system.
Pulseaudio is installed by default, something else must of gone wrong here but to answer your question.
To stop pulse restarting run
echo "autospawn = no" > $HOME/.config/pulse/client.conf
This makes a file client.conf in .config/pulse that disables its autospawn, now you can kill it if you want
pkill -f pulseaudio
The system should fall back on ALSA, post a comment if no audio
Pulse should restart on boot but if it does not and you need it back then remove the file you made
rm $HOME/.config/pulse/client.conf
To stop it restarting at boot
cp $HOME/.config/pulse/client.conf .config/autostart
Mark Kirby
  • 18,949
  • 19
  • 79
  • 116
