I'm running Ubuntu 14.04, I've got a Gigabyte gtx-960 gpu and nvidia drivers installed. Yesterday I set up Synergy, and it was working smoothly. Today once I get to the login screen, every time I log in, it flashes a black screen and returns me to the login screen.
In my limited experience, it seems like xorg is crashing immediately. I've tried the solutions I could find here, including:
- logging into a different user (same problem)
creating a new user (same problem)
logging in via
ctrl+alt+Fn(n = {1-6}) and then doing the following- delete the .Xauthority file
- reinstalling unity
- switch to gdm (which actually made things worse: just gives me a black screen, whenever I hit
ctrl+alt+F3or something, the appropriate screen will show for ~10 seconds, then go black again. I can run commands during that time, and so could switch back to lightdm, but when I type on a black screen, it doesn't do anything). - edit: tried switching to gnome and xubuntu, no luck. This time before kicking me out a pop-up with "System program problem detected - Do you want to report the problem now?"
I've checked .xsession-errors, although honestly I'm not too sure what to make of it... in case it's useful, here's the output:
xlib: extension "GLX" missing on display ":0".
Script for ibus started at run_im.
init: at-spi2-registryd main process ended, respawning
init: gnome-session (Unity) main process (2791) terminated with status 1
init: unity-settings-daemon main process(2781) killed by TERM signal
init: logrotate main process (2688) killed by TERM signal
init: update-notifier-crash (/var/crash/lightdm.0.crash) main process (2722) killed by TERM signal
init: update-notifier-crash (/var/crash/_usr_bin_compiz.1000.crash) main process (2729) killed by TERM signal
init: update-notifier-crash (/var/crash/_usr_lib_ibus-ui-gtk3.1000.crash) main process (2732) killed by TERM signal
init: update-notifier-crash (/var/crash/_usr_lib_ibus_ibus-ui-gtk3.1002.crash) main process (2738) killed by TERM signal
init: update-notifier-crash (/var/crash/_usr_sbin_vbetool.0.crash) main process (2744) killed by TERM signal
init: xsession-init main process (2778) killed by TERM signal
init: hud main process (2785) killed by TERM signal
init: Disconnected from notified D-Bus bus
init: indicator-bluetooth main process (2883) killed by TERM signal
init: indicator-datetime main process (2889) killed by TERM signal
init: indicator-sound main process (2891) killed by TERM signal
init: indicator-printers main process (2894) killed by TERM signal
