I've installed Pale Moon browser in /opt on Ubuntu 14.04. The icon that is displayed in that directory for the Pale Moon program is a simple grey box which when dragged to the gnome launcher bar appears with a question mark on it. Of course, it does run the program.
There is the appropriate "pretty" blue icon, Mozicon128.png in the path /opt/palemoon25.1.0/browser/icons/. Is there a way to replace the box with the question mark on the launcher bar with the Mozicon128.png icon?
andrew.46
  • 39,359
I had the same problem with the icon, and then I found well-maintained repositories for Ubuntu (including kubuntu, lubuntu, etc.) 12.04 - 16.04 14.04 – 18.04 at opensuse. So I followed the instructions to completely de-install Pale Moon, then I added the repository and re-installed with apt-get. For my release of Ubuntu:
sudo sh -c "echo 'deb http://download.opensuse.org/repositories/home:/stevenpusser/xUbuntu_14.04/ /' >> /etc/apt/sources.list.d/palemoon.list"
sudo apt-get update
sudo apt-get install palemoon
Just replace 14.04 with the appropriate release number. (Note that it's a little 'x' with a capital 'U' because it it doesn't mean 'xubuntu'; the 'x' is a like a wildcard, so it means any Ubuntu.) Also add the key (with appropriate release number):
sudo wget http://download.opensuse.org/repositories/home:stevenpusser/xUbuntu_14.04/Release.key
sudo apt-key add - < Release.key
Voila! The icon appears correctly in the launcher, and it is installed no longer in /opt but in the way other Ubuntu applications are, and easily updated besides.
gracious1
  • 531
Install the browser with the installer or create a desktop file:
nano ~/.local/share/applications/palemoon.desktop
with this content
[Desktop Entry]
Version=1.0
Name=Pale Moon Web Browser
Comment=Browse the World Wide Web
Keywords=Internet;WWW;Browser;Web;Explorer
Exec=palemoon %u
Terminal=false
X-MultipleArgs=false
Type=Application
Icon=palemoon
Categories=Network;WebBrowser;Internet;
MimeType=text/html;text/xml;application/xhtml+xml;application/xml;application/rss+xml;application/rdf+xml;image/gif;image/jpeg;image/png;x-scheme-handler/http;x-scheme-handler/https;x-scheme-handler/ftp;x-scheme-handler/chrome;video/webm;application/x-xpinstall;
StartupNotify=true
Actions=NewWindow;NewPrivateWindow;
[Desktop Action NewWindow]
Name=Open a New Window
Exec=palemoon -new-window
OnlyShowIn=Unity;
[Desktop Action NewPrivateWindow]
Name=Open a New Private Window
Exec=palemoon -private-window
OnlyShowIn=Unity;
A.B.
  • 92,125
I did use the Source Forge installer. To fix the problem I found a PPA and installed it. Your mileage may vary but if you don't use a PPA you may have similar problems.
