My previous to last update was showing the following warning:
Generating grub configuration file ...
Warning: Setting GRUB_TIMEOUT to a non-zero value when GRUB_HIDDEN_TIMEOUT is set is no longer supported.
The last update was showing errors from this point on:
Processing triggers for ureadahead (0.100.0-16) ...
ureadahead will be reprofiled on next reboot
Setting up libwnck-3-common (3.4.7-0ubuntu3.1) ...
Setting up libwnck-3-0:amd64 (3.4.7-0ubuntu3.1) ...
Setting up linux-image-3.13.0-52-generic (3.13.0-52.85) ...
Running depmod.
update-initramfs: deferring update (hook will be called later)
Examining /etc/kernel/postinst.d.
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 3.13.0-52-generic /boot/vmlinuz-3.13.0-52-generic
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 3.13.0-52-generic /boot/vmlinuz-3.13.0-52-generic
update-initramfs: Generating /boot/initrd.img-3.13.0-52-generic
gzip: stdout: No space left on device
E: mkinitramfs failure cpio 141 gzip 1
update-initramfs: failed for /boot/initrd.img-3.13.0-52-generic with 1.
run-parts: /etc/kernel/postinst.d/initramfs-tools exited with return code 1
Failed to process /etc/kernel/postinst.d at /var/lib/dpkg/info/linux-image-3.13.0-52-generic.postinst line 1025.
dpkg: error processing package linux-image-3.13.0-52-generic (--configure):
subprocess installed post-installation script returned error exit status 2
Setting up ppp (2.4.5-5.1ubuntu2.2) ...
Setting up dnsmasq-base (2.68-1ubuntu0.1) ...
Setting up gir1.2-wnck-3.0 (3.4.7-0ubuntu3.1) ...
No apport report written because the error message indicates its a followup error from a previous failure.
dpkg: dependency problems prevent configuration of linux-image-extra-3.13.0-52-generic:
linux-image-extra-3.13.0-52-generic depends on linux-image-3.13.0-52-generic; however:
Package linux-image-3.13.0-52-generic is not configured yet.
dpkg: error processing package linux-image-extra-3.13.0-52-generic (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of linux-image-generic:
linux-image-generic depends on linux-image-3.13.0-52-generic; however:
linux-image-generic depends on linux-image-extra-3.13.0-52-generic; however:
Package linux-image-extra-3.13.0-52-generic is not configured yet.
dpkg: error processing package linux-image-generic (--configure):
Setting up linux-headers-3.13.0-52 (3.13.0-52.85) ...
Setting up linux-headers-3.13.0-52-generic (3.13.0-52.85) ...
Setting up linux-headers-generic (3.13.0.52.59) ...
No apport report written because MaxReports is reached already
dpkg: dependency problems prevent configuration of linux-generic:
linux-generic depends on linux-image-generic (= 3.13.0.52.59); however:
Package linux-image-generic is not configured yet.
dpkg: error processing package linux-generic (--configure):
Setting up linux-libc-dev:amd64 (3.13.0-52.85) ...
Processing triggers for libc-bin (2.19-0ubuntu6.6) ...
linux-image-generic
linux-generic
Results of df -h :
Filesystem Size Used Avail Use% Mounted on
/dev/mapper/ubuntu--vg-root 291G 16G 261G 6% /
none 4,0K 0 4,0K 0% /sys/fs/cgroup
udev 1,4G 4,0K 1,4G 1% /dev
tmpfs 288M 1,2M 287M 1% /run
none 5,0M 0 5,0M 0% /run/lock
none 1,5G 272K 1,5G 1% /run/shm
none 100M 48K 100M 1% /run/user
/dev/sda1 236M 208M 16M 94% /boot
/home/mama/.Private 291G 16G 261G 6% /home/mama
Any help please?
