since the kernel upgrade to 4.0.1, because I had a version 3.1x, when you update the driver rtl8192eu not work for me, I get the following error
make [1]:  [_module_ / home / kevin / Desktop / install_folder / driver / rtl8192EU_linux_v4.2.2_7585.20130524] Error 2
make [1]: Leaving directory '/usr/src/linux-headers-4.0.1-040001-generic'
Makefile: 1043: recipe for target 'modules' failed
make:  [modules] Error 2
Compile driver make mistake: 2
Please check mistake Mesg
I tried to go back to the kernel version 3.1x but the problem persists you could do, not much information about this device chipset is 0bda: 818b
otherwise when compiling the 4.0.1 kernel drivers looking in the menuconfig meeting almost every family realtek drivers 8192ex, 8192eu least, is why? Please I need help I've been almost a week with this
the end of the log output (not copy everything because they are almost 500 lines) is as follows
cc1: some errors as warnings Being Treated
make [2]: [/home/kevin/Escritorio/install_folder/driver/rtl8192EU_linux_v4.2.2_7585.20130524/os_dep/li$
make [1]:  [_module_ / home / kevin / Desktop / install_folder / driver / rtl8192EU_linux_v4.2.2_7585.20130524] $
I need help
Maythux
  • 87,123
Kevin AB
  • 131
The procedure described above fails for new kernels (>4.3)
For me it worked fine with as below:
uname -r
4.8.10-040810-generic # output of uname -r
Download the .zip folder from https://github.com/Mange/rtl8192eu-linux-driver.git and expand it
cd  /path_to_the_driver_folder/rtl8192eu-linux-driver-master/
make
sudo make install
sudo depmod -a
sudo modprobe 8182eu
You may need to install some packages (linux-headers-generic build-essential dkms..)
You can also patch using the procedure described on the downloading page : https://github.com/Mange/rtl8192eu-linux-driver.git
For the next arriving kernel linux-4.9 (today = December, 2016), it works too but, in my hands,only after unplugging and re-plugging the device.
Gi_44
I also had this problem, but I found a solution, in this topic: https://forum.ubuntu-nl.org/index.php?topic=86081.25
In Ubuntu 15.04 I had to do the following:
Install this .deb file:
http://users.telenet.be/x86_64/Debian/dkms_rtl8192eu_4.3.1.1.11320.20140505_all.deb
Edit the file:
sudo gedit /usr/src/rtl8192eu-4.3.1.1.11320.20140505/Makefile
And add the following line: EXTRA_CFLAGS += -Wno-date-time
For example:
    EXTRA_CFLAGS += -Wno-unused-variable
    EXTRA_CFLAGS += -Wno-unused-value
    EXTRA_CFLAGS += -Wno-unused-label
    EXTRA_CFLAGS += -Wno-unused-parameter
    EXTRA_CFLAGS += -Wno-unused-function
    #EXTRA_CFLAGS += -Wno-uninitialized
Save the file, and run this command:
sudo dkms autoinstall
Reboot and your wireless internet will work!
