37
How do I install the Google talk plugin so I can use gtalk and Google Plus?
yuttadhammo
  • 1,159
Starting in Ubuntu 11.10 multi-arch is used for applications that formerly used ia32-libs.
gtalk & Google plus are the same plugin. They are are comprised of a 64-bit plugin plus a 32-bit daemon - and use the deprecated ia32-libs, it will be up to Google to update their package at some point.
Under Ubuntu 11.10 amd64 users should continue to use the 64-bit .deb available from http://www.google.com/chat/video on amd64 systems, as the 32-bit .deb cannot be used without additional modifications to the system at this time.
Once downloaded the plugin can be installed by either:
  1. Clicking open in the browser;
  2. Open the file manger, navigate to ~/Downloads and double click on the google plugin deb file;
Either method will open the Software Center to complete the installation. If you receive a dependency error, make sure you have selected Universe in your software sources.
Chema
  • 166
pgraner
  • 690
Here is a hacky way to handle this:
  1. Download the 64-bit .deb from: http://www.google.com/tools/dlpage/res/talkvideo/hangouts/
  2. Create a tmp dir:
    mkdir tmp
  3. Extract the contents of the .deb to the tmp dir:
    dpkg-deb -x google-talkplugin_current_amd64.deb tmp
  4. Extract the control files:
    dpkg-deb --control google-talkplugin_current_amd64.deb tmp/DEBIAN
  5. Fix the dependency:
    sed -i "s/lib32v4l-0/libv4l-0/" tmp/DEBIAN/control
  6. Repackage the .deb:
    dpkg -b tmp google-talkplugin_current_amd64-fixed.deb
  7. Install the fixed version:
    sudo dpkg -i google-talkplugin_current_amd64-fixed.deb
  8. Go to Google to fix their .deb file for 64-bit Oneiric: http://www.google.com/intl/en/+/learnmore/forum/
For ubuntu 14 - there seems to be a bug in the software center, so you'll need to download the file from google servers:
https://www.google.com/tools/dlpage/hangoutplugin
and then use the command line to install the .deb file. Browse to downloads folder:
cd ~/Downloads/
Install .deb file via command line:
sudo dpkg -i <google-talk-file.deb>
Install from the official Google repo following these instructions:
sudo sh -c 'echo "deb http://dl.google.com/linux/talkplugin/deb/ stable main" >> /etc/apt/sources.list.d/google-talkplugin.list'
wget -q -O - https://dl-ssl.google.com/linux/linux_signing_key.pub | sudo apt-key add -
sudo apt-get update
sudo apt-get install google-talkplugin
Cerin
  • 6,923
