# apt-get dist-upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
2 not fully installed or removed.
Need to get 0 B/5,258 B of archives.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
dpkg: error processing package update-manager-core (--configure):
package is in a very bad inconsistent state; you should
reinstall it before attempting configuration
dpkg: dependency problems prevent configuration of update-manager:
update-manager depends on update-manager-core (= 1:0.196.13); however:
Package update-manager-core is not configured yet.
dpkg: error processing package update-manager (--configure):
dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
Asked
Active
Viewed 2.2k times
A.B.
- 92,125
nazihhizan
- 109
- 2
- 2
- 11
After around two hours of searching I found that I have to run those 2 commands..
sudo apt-get install --reinstall update-manager-core
Elder Geek
- 36,752
nazihhizan
- 109
- 2
- 2
- 11
