-1
I have Ubuntu 14.04 installed on an SSS running perfectly. Got a new 2TB drive that has Windows 7 installed on it.
How do I add Windows 7 to my grub menu?
This is output of sudo update-grub:
Searching for GRUB installation directory ...
found: /boot/grub Searching for default file ...
found: /boot/grub/default Testing for an existing GRUB menu.lst file ...
found: /boot/grub/menu.lst Searching for splash image ...
none found, skipping ...
Found kernel: /boot/vmlinuz-3.13.0-51-generic
Found kernel: /boot/vmlinuz-3.13.0-49-generic Found kernel: /boot/vmlinuz-3.13.0-24-generic
Found kernel: /boot/memtest86+.bin Updating /boot/grub/menu.lst ... done
This is the output of sudo os-prober:
sudo os-prober /dev/sdc1:Windows 7 (loader):Windows:chain
Tim
  • 33,500
Run the command sudo update-grub.
If it still does not work try boot-repair. It will attempt to fix the problem, if it can't it will provide a link with all the information we need to further troubleshoot the issue.
Pabi
  • 7,429
