I've installed f.lux some time ago and also had it in my startup apps. But now, all of a sudden, it doesn't startup automaticall anymore. I have the command "fluxgui" in my startup applications. If I open it from console, it works without a problem. Can I somehow debug, why the program was not auto started?
Asked
Active
Viewed 4,206 times
I've experienced the same issue.
Changing the Exec field in ~/.config/autostart/fluxgui.desktop to sh -c "fluxgui >> ~/logflux.txt 2>&1" would allow you to examine the reason for the failure to start-up.
I've got the following traceback:
Traceback (most recent call last):
File "/usr/lib/pymodules/python2.7/fluxgui/fluxgui.py", line 381, in <module>
app = Fluxgui()
File "/usr/lib/pymodules/python2.7/fluxgui/fluxgui.py", line 17, in __init__
self.indicator = Indicator(self)
File "/usr/lib/pymodules/python2.7/fluxgui/fluxgui.py", line 149, in __init__
self.setup_indicator()
File "/usr/lib/pymodules/python2.7/fluxgui/fluxgui.py", line 162, in setup_indicator
'gtk-icon-theme-name')
ValueError: could not find setting
Apparently, this is a known bug. However, a workaround is provided by @sricks:
This bug is still present. BUT you can fix it by modifying line 162 of
/usr/lib/pymodules/python2.7/fluxgui/fluxgui.py.Change the
theme =line to look liketheme = 'ubuntu-mono-dark'. If you don't have that theme installed, no problem, it just uses a default. Lines161,162, and163should look like this:if gtk.gdk.screen_get_default(): theme = 'ubunto-mono-dark' if theme == 'ubuntu-mono-dark':
This fixed the issue for me.
Avidan Borisov
- 126
