I'm trying to copy data to an excel file using xlwt in a python code
  worksheet.write(globdat.cycle,1,fint)
globdat.cycle is a count. No problems there since it gets values 1, 2.... n in each iteration.
BUT
'fint' is an array with an unknown number of entries so I cannot exactly give the number of columns.
How can I be able to copy all the values in 'fint' to the excel file ?
dyon
  • 31
You need to loop the array and call worksheet.write for each item. You have to specify which row/column you're writing to so we can use the builtin enumerate to count out each item in the array.
You want something like this:
for i, fintitem in enumerate(fint, start=1):
    worksheet.write(globdat.cycle, i, fintitem)
Oli
  • 299,380
