The recommended/normal procedure is to install click build targets in Ubuntu SDK but I wanted to know if it's possible to install them in terminal.
Asked
Active
Viewed 2,081 times
AFAIK the recommended way is to use pkcon. Copy your .click file to the device and run the following command on the device itself (by using adb shell or SSH):
pkcon --allow-untrusted install-local com.ubuntu.developer.abc.def_0.123_armhf.click
This does not require root privileges.
Cmdr
- 209
You can use the click command to install packages on your device.
First copy the .click file on your device.
Then use the following commands (e.g after creating a remote session with phablet-shell):
sudo click install --all-users ./com.ubuntu.foo_1.0.click --allow-unauthenticated
click register com.ubuntu.foo 1.0
Just change the name of the package for your needs.
Sylvain Pineau
- 63,229
