Determine your current BIOS flavor and version
Press F1 at boot to enter the BIOS setup. Here you should find the following:
UEFI BIOS Version H?ETxxWW(y.yy)
UEFI BIOS Date (Year-Month-Day) YYYY-MM-DD
Embedded Controller Version H?ECxxWW(y.yy)
where ? is 1, 5, or 9. I will call this the "flavor".
xx and y.yy signify the version. We're only concerned with the UEFI BIOS Version, not the Embedded Controller Version.
Mine looks like this, I have the "H5" flavor and will need to install the files that begin with "H5":
UEFI BIOS Version H5ET69WW (1.12 )
UEFI BIOS Date (Year-Month-Day) 2012-11-15
Embedded Controller Version H5EC31WW(1.11)
Understanding versions and available files
Currently these three versions are available:
Even though the filenames indicate the "H9" flavor, the first two also contain BIOS updates for the "H1" and "H5" flavors. h9et75ww.zip contains these versions:
- H1ET80WW
- H5ET80WW(1.19) 2013-09-09, EC: H5EC33WW(1.13)
- H9ET75WW
When run, h9et84ww.exe extracts its contents to a directory, which contains these versions:
- H1ET85WW
- H5ET85WW(1.23) 2014-04-15, EC: H5EC34WW(1.14)
- H9ET84WW
Based on the file size, I believe h9et92ww.exe only contains H9ET92WW for the "H9" flavor.
Note that the two digits before 'WW' are different for the "H9" flavor as compared to the others. I've provided the version, date, and embedded controller version for the "H5" flavor after upgrading. h9et84ww.txt contains lots of conflicting information about versions and dates, and should not be trusted.
It is not clear whether the instructions to upgrade to H9ET75WW before upgrading to H9ET84WW or H9ET92WW only apply to the "H9" flavor, or all flavors. For safety, you should probably upgrade them sequentially on all flavors.
Installing h9et75ww.zip
This contains DOS executables.
- Install a live version of FreeDOS to a USB stick.
- Extract h9et75ww.zip to that USB stick.
- Ensure your battery is charged and that the charger is connected. The installer will check your battery level and abort if it is too low.
- Press F12 at boot, select to boot from your USB stick.
- Once FreeDOS is running, cd to the
DOS subdirectory of the files you extracted in step 2.
- Run the
H?ETxxWW.BAT script that corresponds to your particular flavor, substituting ? as appropriate.
The output will look something like this:
bat_cap= 100
Don't clean variable
Phoenix SCT Flash for DOS V1.3.26.1, Build 120810
Copyright (c) 2011-2012 Phoenix Technologies Ltd.
SecureFlash BIOS detected.
Read BIOS image from file.
Initialize Flash module.
Read current BIOS.
WARNING: System is going to shutdown and do capsule update!
WARNING: System will shutdown or reboot in 5 seconds!
Let it reboot. After the reboot, you should see it flash the BIOS:
Phoenix SCT Flash for Shell V1.3.26.1, Build 120810
Read BIOS image from memory.
Prepare to flash "bios"
Begin Flashing......
Total blocks of the image = 992.
Image flashing done.
Flashing finished.
Prepare to flash "ec"
Total blocks of the image = 32.
Flashing finished.
BIOS is updated successfully.
Let it reboot again, and you are done.
Installing h9et84ww.exe
This installer is unfortunately not a self-extracting zip file.
- Install wine.
- Use wine to run
h9et84ww.exe. This should bring up an installation wizard.
- Accept the license agreement.
- Let the wizard extract the files.
- After extracting, un-check the box to "Install ThinkPad BIOS Update Utility now", and click Finish.
This would launch winuptp.exe that it just extracted, but it does not work under wine. It also does not work under FreeDOS. We need to find a different way to install it.
Browse to the directory containing the files it extracted in step 4. You should find the subdirectories H1ET85WW, H5ET85WW, and H9ET84WW. Each contains a single file named $0AH?000.FL1 where ? is the flavor. These are the same size and likely the same format as the .cap files in h9et75ww.zip. So let's use the same FreeDOS USB stick as before, but using the updated files instead.
- Copy the relevant
$0AH?000.FL1 file to the DOS directory of the USB stick, renaming it to H?ETxxWW.cap, and substituting ? and xx as appropriate.
- Edit the relevant
H?ETxxWW.BAT script. Near the top should be a line such as set NVROMCAP=H5ET80WW.cap. Adjust this to refer to the file you copied in step 6.
- Boot to the USB stick and install it as before.
Installing h9et92ww.exe
To be determined.
