After upgrading from 14.04 to 15.04, my Bluetooth is not working anymore. I don't have the icon in the taskbar. When I go to Bluetooth in System Settings, it says Bluetooth disabled. Does anyone have an idea of how to fix this? I have attached a few details that could be useful. Thank you in advance.
$ sudo rfkill list all
0: hci0: Bluetooth
    Soft blocked: no
    Hard blocked: no
1: phy0: Wireless LAN
    Soft blocked: no
    Hard blocked: no
$ sudo service bluetooth status
 bluetooth.service - Bluetooth service
   Loaded: loaded (/lib/systemd/system/bluetooth.service; disabled; vendor preset: enabled)
   Active: inactive (dead)
     Docs: man:bluetoothd(8)
$ sudo lsusb; uname -a; lsmod | grep bluetooth; dmesg | grep -i firmware
Bus 003 Device 005: ID 2232:1024
Bus 003 Device 004: ID 0cf3:3004 Atheros Communications, Inc.
Bus 003 Device 003: ID 2341:0043 Arduino SA Uno R3 (CDC ACM)
Bus 003 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 1532:0016 Razer USA, Ltd DeathAdder Mouse
Bus 001 Device 003: ID 2516:0020
Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB
Linux felipe-900X3F 3.19.0-15-generic #15-Ubuntu SMP Thu Apr 16 23:32:37 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
bluetooth             491520  3 ath3k,btusb
[    2.140866] psmouse serio1: elantech: assuming hardware version 4 (with firmware version 0x575f00)
Byte Commander
  • 110,243
Felipe
Have you tried the solution in https://askubuntu.com/a/613622/132783 ?
That is:
wget https://www.dropbox.com/s/r2pb41rhx65t9zi/BCM20702A0-0a5c-216f.hcd
sudo cp BCM20702A0-0a5c-216f.hcd /lib/firmware/brcm/
sudo modprobe -r btusb
sudo modprobe btusb
Gorka
  • 315
