I regularly uses xterm for web browsing because of its image rendering property but the one thing which makes xterm difficult comparing to terminal is the copy/cut paste availability in terminal program. I have found this method and according to this i saved the below code in .Xdefaults file in home directory
xterm -ls -xrm 'XTerm*selectToClipboard: true'&
After the implementation of this code I am able to select text in xterm but not able to copy or cut paste (using mouse or keyboard shortcuts ctrl+c etc) any text from or to the xterm.
Any idea what went wrong?
Eka
  • 3,007
You can edit the XTerm file using vim or nano (I use vim):
vim /home/your_user_name/XTerm
Add this:
XTerm*Background: black
XTerm*Foreground: green
XTerm*SaveLines: 2000
XTerm*faceName: Ubuntu mono
XTerm*faceSize: 12
XTerm*rightScrollBar: true
XTerm*ScrollBar: true
XTerm*scrollTtyOutput: false
XTerm*VT100.Translations: #override \
      Shift Ctrl<Key>V: insert-selection(CLIPBOARD) \n\
      Shift Ctrl<Key>V: insert-selection(PRIMARY) \n\
      Shift<Btn1Down>: select-start() \n\
      Shift<Btn1Motion>: select-extend() \n\
      Shift<Btn1Up>: select-end(CLIPBOARD) \n\
Save and close with:
:wq
Open xterm:
xterm &
The above configuration does four things:
  1. Select and copy text into xterm:
    • Hold the Shift key.
    • Click the left mouse button.
    • Select your text.
    • Click the right mouse button to add it to the clipboard.
  2. Paste text into xterm by pressing Ctrl+Shift+V.
  3. Show the scrollbar.
  4. Customize the font.
simonced
  • 201
You shall not include that line in .Xdefaults. Thus shalt thou start the program.
xterm -ls -xrm 'XTerm*selectToClipboard:true' &
Or with .Xdefaults:
Add this line:
and reload the configuration
xrdb ~/.Xdefaults
A.B.
  • 92,125
Handling shortcuts in Xterm
In Edit keyboard shortcuts you can than set what you want. Obviously if some key combination is taken you have to clear that assignment first from current use in order to use it for your commands.
Hrvoje
  • 131
