I faced the same authentication error with pam_service_name=vsftpd.
Following advice online, I couldn't work out why setting pam_service_name=ftp fixed the problem so I tested setting this to pam_service_name=foobar and it also fixed the issue!
Disclaimer: I too am new to linux however I believe the generally accepted advice to set pam_service_name=ftp is wrong.
pam_service_name=vsftpd selects the existing configuration file /etc/pam.d/vsftpd, however pam_service_name=ftp will look for /etc/pam.d/ftp which does not exist (at least on my system - Ubuntu 14.04.2 LTS). I suspect this is actually bypassing the PAM authentication without complaining it can't find the file.
By not using a valid PAM config, it may less secure.
Final solution
I ended up keeping pam_service_name=vsftpd and made sure the user's shell existed in the /etc/shells file. http://www.cyberciti.biz/tips/howto-linux-shell-restricting-access.html
Looking at /etc/pam.d/vsftd
# Standard behaviour for ftpd(8).
auth required pam_listfile.so item=user sense=deny file=/etc/ftpusers onerr=succeed
# Note: vsftpd handles anonymous logins on its own. Do not enable pam_ftp.so.
# Standard pam includes
@include common-account
@include common-session
@include common-auth
auth required pam_shells.so
My issue was that it was failing at the auth required pam_shells.so step. I had made all my FTP users use the /usr/sbin/nologin shell which didn't exist in the /etc/shells file (non-ubuntu this might be just /sbin/nologin). If you're not sure, try commenting out the auth required pam_shells.so to see if this is the cause when pam_service_name=vsftpd.
Note: Further reading suggests it is cleaner to instead create virtual users but this requires different vsftpd and PAM configuration - http://www.sigerr.org/linux/setup-vsftpd-custom-multiple-directories-users-accounts-ubuntu-step-by-step/.
