I found the source in launchpad for 11.04 and 10.10 but I don't know how to install or compile it.
Update: The PPA mentioned below doesn't currently provide packages for 13.10/saucy and newer releases. You could try to install the 13.04/raring packages by modifying the corresponding sources.list file in /etc/apt/sources.d/ but that is not a recommended workaround.
11.04 and 11.10
I can't answer directly how to compile the source. However, I've tested the following on a virtual guest install on oneiric.
Note if you look at the series available for the PPA it will tell you which distro version this PPA has been compiled for. At the time of writing - 11.04 (Natty), 11.10 (Oneiric), 12.04 (Precise)
as all stuff that changes your boot - back things up first with a good image backup
sudo add-apt-repository ppa:n-muench/burg
sudo apt-get update
Now install the remaining packages:
sudo apt-get install burg burg-common burg-emu burg-pc burg-themes burg-themes-common
During the installation you will be asked to select the drive you want to install on - press the spacebar to "*" the drive you want for example /dev/sda.
Linked Questions:
- 174,526
First, install it:
sudo apt-get update
sudo apt-get install burg burg-themes
Now, actually install it (replace hd0 with the device to install it to):
sudo burg-install "(hd0)"
And update it:
sudo update-burg
And test it using the emulator:
sudo burg-emu
- 4,950
Also worth looking at is Super-Boot-Manager, this allows you to configure Grub, Burg and Plymouth, through a simple GUI and a revert to GRUB option
sudo add-apt-repository ppa:ingalex/super-boot-manager
sudo apt-get update
sudo apt-get install buc super-boot-manager
- 43
