-1
When i install 32-bit libraries through command
sudo apt-get install 32-bit
libraries.Error occurred unable to locate package.
Please give me solution of this error.
Maythux
  • 87,123
your problem is in
There is no package called 32-bit for that you got this error
you should use the following
sudo apt-get install ia32-libs
PS if you use Ubuntu 13.10 or higher, you'll need install these packages instead:
sudo apt-get install lib32z1 lib32ncurses5 lib32bz2-1.0
Maythux
  • 87,123
