I have turned off power management for my wireless. I did that in /etc/pm/power.d/wireless.
When I try to connect to a network, the power management turns back on. So the connection fails.
I try:
sudo iwconfig wlan0 power off
The power management is then off, but when I connect it is turned back on.
I added a service as detailed here, it is now initially off. When I try to connect, the power management turns on again.
Output of lshw -C network:
*-network
   description: Wireless interface
   product: Wireless 7260
   vendor: Intel Corporation
   physical id: 0
   bus info: pci@0000:02:00.0
   logical name: wlan0
   version: 6b
   serial: <redacted>
   width: 64 bits
   clock: 33MHz
   capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
   configuration: broadcast=yes driver=iwlwifi driverversion=3.19.0-15-generic firmware=25.15.12.0 latency=0 link=no multicast=yes wireless=IEEE 802.11abgn
   resources: irq:43 memory:f0400000-f0401fff
*-network DISABLED
   description: Ethernet interface
   physical id: 1
   logical name: virbr0-nic
   serial: <redacted>
   capabilities: ethernet physical
   configuration: autonegotiation=off broadcast=yes driver=tun driverversion=1.6 duplex=full link=no multicast=yes port=twisted pair speed=10Mbit/s
What is happening here? Can I try anything else?
Hooks in /etc/pm/ are ignored in Ubuntu 15.04. Instead you have to create systemd services and enable them.
Although first try adding
sleep 10
iwconfig wlan1 power off
exit 0
to your /etc/rc.local file. This should turn of power management at boot and might help with the connection. To permanently disable the power management look here.
More info about hooks in /etc/pm not working anymore here. To create systemd services have a look at ArchWiki.
Hope this helps.
This had nothing to do with Ubuntu.
My ISP, which also handles my wifi, blocked it because I did not pay in time.
