cat file1
foo
ice
two
cat file2
bar
cream
hundred
Desired output:
foobar
icecream
twohundred
file1 and file2 will always have the same amount of lines in my scenario, in case that makes things easier.
cat file1
foo
ice
two
cat file2
bar
cream
hundred
Desired output:
foobar
icecream
twohundred
The right tool for this job is probably paste
paste -d '' file1 file2
See man paste for details.
You could also use the pr command:
pr -TmJS"" file1 file2
where
-T turns off pagination-mJ merge files, Joining full lines-S"" separate the columns with an empty string If you really wanted to do it using pure bash shell (not recommended), then this is what I'd suggest:
while IFS= read -u3 -r a && IFS= read -u4 -r b; do
printf '%s%s\n' "$a" "$b"
done 3<file1 4<file2
(Only including this because the subject came up in comments to another proposed pure-bash solution.)
paste is the way to go. If you want to check some other methods, here is a python solution:
#!/usr/bin/env python2
import itertools
with open('/path/to/file1') as f1, open('/path/to/file2') as f2:
lines = itertools.izip_longest(f1, f2)
for a, b in lines:
if a and b:
print a.rstrip() + b.rstrip()
else:
if a:
print a.rstrip()
else:
print b.rstrip()
If you have few number of lines:
print '\n'.join((a.rstrip() + b.rstrip() for a, b in zip(f1, f2)))
Note that for unequal number of lines, this one will end at the last line of the file that ends first.
Also, with pure bash (notice that this will totally ignore empty lines):
#!/bin/bash
IFS=$'\n' GLOBIGNORE='*'
f1=($(< file1))
f2=($(< file2))
i=0
while [ "${f1[${i}]}" ] && [ "${f2[${i}]}" ]
do
echo "${f1[${i}]}${f2[${i}]}" >> out
((i++))
done
do
echo "${f1[${i}]}" >> out
((i++))
done
while [ "${f2[${i}]}" ]
do
echo "${f2[${i}]}" >> out
((i++))
done
The perl way, easy to understand:
#!/usr/bin/perl
$filename1=$ARGV[0];
$filename2=$ARGV[1];
open(my $fh1, "<", $filename1) or die "cannot open < $filename1: $!";
open(my $fh2, "<", $filename2) or die "cannot open < $filename2: $!";
my @array1;
my @array2;
while (my $line = <$fh1>) {
chomp $line;
push @array1, $line;
while (my $line = <$fh2>) {
chomp $line;
push @array2, $line;
for my $i (0 .. $#array1) {
print @array1[$i].@array2[$i]."\n";
Start with:
./merge file1 file2
Output:
foobar
icecream
twohundred
