I am trying to install Matlab 8.01 (64-bit installer) on my Ubuntu 15.04 (64-bit). After typing,
sudo ./install
Matlab installer starts and installer appears but within a few seconds it disappears with following information at the Terminal.
Exception in thread "main" com.google.inject.ProvisionException: Guice provision errors:
1) Error in custom provider, java.lang.RuntimeException: java.lang.reflect.InvocationTargetException
... [Some more technical information]
... 62 more
I already installed
default -jre
Please guide me. I am really desperate to see Matlab running on my Ubuntu.
EDIT:
Matlab Folder has bin/glnxa64 folder. So this is a 64-bit installer?
a.s.
  • 113
This is a very good guide page for me and if you follow it you will get Matlab installed. They are discussing the Java problem there too.
My understanding is that the Matlab version you are using is old and that you have installed java but not the java development kit (jdk). Probably you will need to either install a newer Matlab version or install an older java (java 6),
To see the version of java installed use the command:
java -version
or
file /etc/alternatives/java /etc/alternatives/javac
Here and here you can find how to install java.
To get a more verbose output from Matlab add -v to the installation command.
sudo /<matlab_directory>/install -v
Hope this helps you.
