My system has been running fine with the abovementioned card on Ubuntu 14.04 and 14.10 for about 2 months. After performing a full reinstall of Ubuntu (to 14.04 again), I have been encountering X.org crashes which sometimes provides me with the dreaded "The system is running in low graphics mode" popup, or sometimes causes my screen to flicker on and on forever till reboot. I decided to upgrade back to 14.10 and kernel version 3.18 in hopes of preventing these errors but to no avail.
From what I have gathered, I've tracked the issue to my graphics card, as seen in kern.log and Xorg.log.
Kern.log:
radeon 0000:01:00.0: ring 0 stalled for more than 10484msec
radeon 0000:01:00.0: GPU lockup (current fence id 0x000000000078af4a last fence id 0x000000000078afcb on ring 0)
Xorg.0.log: (I can't find a copy right now that produces the error, but it's along the lines of:)
radeon_dri2_flip_event_handler: Pageflip completion event has impossible msc 1863 < target_msc 1864
I've tried finding solutions online but the only solution I've found is to... buy a new graphics card :( which I want to avoid if I can.
My current driver installed is radeon (output from lspci -v), not fglrx, though I'm not sure if I should try, maybe in a few days when my work is less busy. I was hoping if someone could point me in the right direction as to what I should try and if anyone else faces the same problem.
I am using a Gigabyte GA-Z97-D3H motherboard and a Sapphire Vapor-X R9 280X card, if it helps.
I am this close to just purchasing Nvidia instead..... sigh.
Irvin Lim
  • 166
