If you use the sudo blkid command to view partitions with their uuids or just view the /etc/fstab (considering you have got some NTFS partitions) you will probably notice that UUIDs of the NTFS partitions are 16 characters long with no dashes while ext2/3/4 and swap partitions have got traditional 32-char (16-byte) long UUIDs with dashes. Why so?
- 58,745
Because those values aren't UUIDs; they're NTFS serial numbers. They're identified as UUIDs in /etc/fstab (and elsewhere) because the developers chose to use the identifier "UUID" for fundamentally non-UUID data, rather than use some other identifier.
The same is true of FAT, by the way, but FAT serial numbers are even shorter than NTFS serial numbers.
- 45,120
- 7
- 66
- 108
The Microsoft filesystems (NTFS and the FAT brothers) don't support UUIDs the way ext*/btrfs/other Unixy filesystems do. What you see reported as UUIDs are some sort of serial numbers (64 bits long for NTFS, 32 bits long for FAT32). The only concrete information I can dig up from the Linux world is from the ntfslabel(8) manpage:
--new-serial[=ssssssssssssssss], or
--new-half-serial[=ssssssss]
Set a new serial number to the device, either the argument
value, or a random one if no argument is given. The serial
number is a 64 bit number, represented as a sixteen-digit
hexadecimal number, used to identify the device during the
mounting process. As a consequence, two devices with the same
serial number cannot be mounted at the same time on the same
computer. This is not the volume UUID used by Windows to locate
files which have been moved to another volume.
The option --new-half-serial only changes the upper part of the
serial number, keeping the lower part which is used by Windows
unchanged. In this case the optional argument is an eight-digit
hexadecimal number.
I suspect that these "UUID"s maybe the same as the serial number report by fsutil on Windows.
- 207,228
