10
There used to be a vaapi build of mplayer but it doesn't seem to be maintained any more and doesn't work in Vivid.
Default mplayer2 build from the repo uses 40% of CPU during 720p playback. Same as totem. VLC does have some hardware acceleration support and uses 13% but I liked mplayer's UI more and it used less than 5% with.
Is it currently possible to use mplayer with hardware acceleration on Intel integrated graphics?
OK, I found mpv (a fork of mplayer) which does everything I wanted and carried all the good UI qualities from mplayer2.
To enable vaapi support, run it with mpv --vo=opengl-hq --hwdec=vaapi file.mkv
or add
vo=opengl-hq
hwdec=vaapi
to ~/.config/mpv/mpv.conf.
Previously the answer suggested using vo=vaapi and hwdec=vaapi but this is not a recommended setup anymore. See comments.
-3
SNA is the best acceleration method. You should check your config file if you have one. Another way is to renice the process. For example:
ps ax|grep mplayer
find the given process and renice it
renice -20 43332
You can do it as root only (maybe it is possible with sudo: sudo renice -20 43332 ).
