VLC was working fine until I upgraded to 15.04. When I try to install via Software Centre, I get this error message:
 vlc: Depends: vlc-nox (= 2.2.0-1) but 2.2.0+ppa2.4 is to be installed
 Depends: libavcodec-extra-56 (>= 6:11.2) but 6:11.2-1 is to be installed
 Depends: libavutil54 (>= 6:11~beta1) but 6:11.2-1 is to be installed
 Depends: libc6 (>= 2.16) but 2.21-0ubuntu4 is to be installed
 Depends: libegl1-x11 but it is a virtual package
 Depends: libfreetype6 (>= 2.2.1) but 2.5.2-2ubuntu3 is to be installed
 Depends: libgcc1 (>= 1:4.1.1) but 1:5.1~rc1-0ubuntu1 is to be installed
 Depends: libgles1 but it is a virtual package
 Depends: libgles2 but it is a virtual package
 Depends: libqtcore4 (>= 4:4.8.0) but 4:4.8.6+git64-g5dc8b2b+dfsg-3~ubuntu6 is to be installed
 Depends: libqtgui4 (>= 4:4.8.0) but 4:4.8.6+git64-g5dc8b2b+dfsg-3~ubuntu6 is to be installed
 Depends: libstdc++6 (>= 4.9) but 4.9.2-10ubuntu13 is to be installed
 Depends: zlib1g (>= 1:1.2.3.3) but 1:1.2.8.dfsg-2ubuntu1 is to be installed
And via Terminal:
The following information may help resolve the situation:
 vlc : Depends: vlc-nox (= 2.2.0-1) but 2.2.0+ppa2.4 is to be installed
       Recommends: vlc-plugin-notify (= 2.2.0-1) but it is not going to be installed
       Recommends: vlc-plugin-samba (= 2.2.0-1) but it is not going to be installed
When I do dpkg --get-selections | grep hold it appears that no packages are being held
When I do dpkg --get-selections | grep vlc it shows this:
libvlc5                     install
libvlccore8                 install
vlc-data                    install
vlc-nox                     install
Also when I try to remove it via Terminal it says it is not installed and therefore cannot be removed. I have also tried the daily release videolan ppa with the same unfortunate results. How can I get my good old VLC back? Thanks for your help!
paulj
  • 83
The problem seems to be in vlc-nox, that is not removed when Ubuntu is upgraded. If you remove it at first, everything should work OK. Something like that:
sudo apt-get remove vlc-nox
sudo apt-get autoremove
sudo apt-get update
And then install vlc (3.0 worked for me):
sudo add-apt-repository ppa:videolan/master-daily
sudo apt-get update
sudo apt-get install vlc
That should make it work. This PPA contains daily changing, potentially unstable or broken development builds. See the PPA description:
This PPA contains daily builds from the VLC development branch.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
