I've installed a fresh copy of Xubuntu 15.04 and I can't get my Broadband B4311 Wifi card working. I had Ubuntu GNOME 14.04, and I solved the problem using the b43 driver, so I'd already done a lot of tweaking, now neither the b43 driver or the Broadcom proprietary driver works. Is this kernel related? Has anyone had the same problem?
karel
  • 122,292
  • 133
  • 301
  • 332
Correction:
Actually, the correct file to edit on gedit is /etc/modprobe.d/blacklist-bcm43.conf since this file is for the Broadcom 43xx series wifi chipsets. Don't forget to reboot the PC once these changes are made to take into effect.
So to put it into steps (for some people who don't get what I'm talking about):
Open Terminal by pressing Ctrl+Alt+T
Type
sudo apt-get install firmware-b43-installer
gksudo gedit /etc/modprobe.d/blacklist-bcm43.conf
Comment out (by putting a # at the start of the line) any items with the words bcm43 or bcm43xxx in them. Save the file and close gedit once you're done with these changes.
Reboot the PC.
NOTE: some PCs may require you to activate the wifi card through either a combo key press (FN + F# or an unknown side/front switch) before you can see your wifi networks on the Network Connections.
Zanna
  • 72,312
sudo -H gedit /etc/modprobe.d/blacklist-broadcom-wireless.conf
removed the line with b43
sudo update-initramfs -u
Details found here on the help.ubuntu.com wiki
Zanna
  • 72,312
