Whenever I try to open a file, for example within gedit, an application crashes immediately. The same happens with other apps. If it does matter, I'm connecting to ubuntu remotely via VNC. Here is the stacktrace:
 *** glibc detected *** gedit: malloc(): memory corruption: 0x000000000130b8e0 ***
======= Backtrace: =========
/lib/libc.so.6(+0x774b6)[0x7fb39b50f4b6]
/lib/libc.so.6(+0x7b55f)[0x7fb39b51355f]
/lib/libc.so.6(__libc_malloc+0x6e)[0x7fb39b51438e]
/usr/lib/libpixman-1.so.0(+0x1724b)[0x7fb3982a324b]
/usr/lib/libpixman-1.so.0(pixman_image_create_solid_fill+0x9)[0x7fb3982c48b9]
/usr/lib/libpixman-1.so.0(pixman_image_fill_boxes+0x23a)[0x7fb3982be63a]
/usr/lib/libstdc++.so.6.0.14
7fb38ab43000-7fb38ad42000 ---p 000e8000 09:02 133465                     /usr/lib/libstdc++.so.6.0.14
7fb38ad42000-7fb38ad4a000 r--p 000e7000 09:02 133465                     /usr/lib/libstdc++.so.6.0.14
7fb38ad4a000-7fb38ad4c000 rw-p 000ef000 09:02 133465                     /usr/lib/libstdc++.so.6.0.14
7fb38ad4c000-7fb38ad61000 rw-p 00000000 00:00 0
7fb38ad61000-7fb38ad6c000 r-xp 00000000 09:02 8257554                    /usr/lib/enchant/libenchant_ispell.so
7fb38ad6c000-7fb38af6c000 ---p 0000b000 09:02 8257554                    /usr/lib/enchant/libenchant_ispell.so
7fb38af6c000-7fb38af6d000 r--p 0000b000 09:02 8257554                    /usr/lib/enchant/libenchant_ispell.so
7fb38af6d000-7fb38af6e000 rw-p 0000c000 09:02 8257554                    /usr/lib/enchant/libenchant_ispell.so
7fb38af6e000-7fb38afae000 r-xp 00000000 09:02 134452                     /usr/lib/libibus.so.2.0.0
7fb38afae000-7fb38b1ae000 ---p 00040000 09:02 134452                     /usr/lib/libibus.so.2.0.0
7fb38b1ae000-7fb38b1af000 r--p 00040000 09:02 134452                     /usr/lib/libibus.so.2.0.0
Any ideas? Thanks
Jorge Castro
  • 73,717
The short answer is: file the bug in Launchpad, using ubuntu-bug, against any relevant package. Filing a good bug, even if it's against the wrong package, is still useful: it's easy for someone better placed to redirect it in to the right one, and much easier than dealing with a bug that doesn't have a stacktrace or other technical information.
As far as which package it should go against:
  1. Filing against one application that does show the problem is a good place to start.
  2. Choosing the package corresponding to the innermost stack frame that's not really generic like libc would also be reasonable, so (just going off what you show here) libpixman could be reasonable.
  3. The file dialog for gedit comes from libgtk2 (or maybe libgtk3 depending) so that could also be ok.
This stack trace looks truncated so getting the actual right one by reporting with ubuntu-bug would be much better.
poolie
  • 9,358
