I've got a nice little BQ Aquaris E4.5 Ubuntu Edition here and I'm trying it out. Is there a sensible way to install Git on it? It doesn't appear to be available via the default repositories.
muru
  • 207,228
d3pd
  • 3,791
Easiest way I found so far is to just download the armhf build of git from launchpad, extract it on my desktop and copy the contents to my phone. Then I can just run the git binary from where I have it copied to.
The latest armhf builds for git can be found here:
https://launchpad.net/ubuntu/utopic/armhf/git/
Download the deb of one of the builds and extract it (either with file-roller or with dpkg -x). After you extracted the deb, you'll have, among others, a usr/ dir which should contain everything you need to run git.
Upload that dir to your phone, so that its in your home, then just run
/home/phablet/usr/bin/git
and it should work. It'll complain about not finding templates when you do git init, but you can run it with
env GIT_TEMPLATE_DIR=/home/phablet/usr/share/git-core/templates /home/phablet/usr/bin/git init
to fix that problem.
If you don't want to type the full path every time you want to run git, you can set an alias in your .bashrc:
alias git=/home/phablet/usr/bin/git
rakete
  • 413
Try unlocking the Ubuntu file system first:
$ sudo mount -o remount, rw /
Then deleting the lock files to install applications:
$ sudo rm -f  /var/lib/apt/lists/lock
$ sudo rm -f /var/lib/dpkg/lock
Rinzwind
  • 309,379
